I have been exporting selected models as .fbx for Unity, and all of a sudden that is not an option in the types of files menu. Nothing has been deleted, and I had just exported and saved a file right before this problem started. I am working in an Educational License of Maya 2014. I saw on some posts that fbx is a plug-in, but I do not see where to download a plug-in for 2014.
Thank you for your help
Hello jkn30,
Thank you for posting on the forums.
There are two things I would recommend checking:
1) Be sure that the FBX plugin is loaded. You can do this by going to Window > Settings\Preferences > Plugin Manager. In the plugin manager window you should see FBX. Be sure that it is loaded you can also set it to Auto-load.
2) I would recommend defaulting your maya preferences. Sometimes these become corrupt and can cause problems. You can do this by using the steps outlined in the following link:
http://forums.autodesk.com/t5/Maya-General/Resetting-the-Maya-Preferences/td-p/4419749
I hope this information is helpful.
Cheers,
