So I've been looking for answers to this question (and variations thereof) all over Google and it seems to be generally unanswered or nonexistent for some reason.
I asked an Autodesk agent about it and the best they could do is link me this page on AutoCAD Architecture but noted that this pertains to all Autodesk software:
However, this only explains what will cause a "student edition" warning to pop up and doesn't mention anything about whether importing such file types into a licensed copy is "compliant," I think is the word Autodesk uses.
Basically I'm wondering if I can move some old work from the student edition into a licensed copy, finish it there and still be able to use it commercially.
Thanks in advance
Solved by Steve_Curley. Go to Solution.
Thanks for the links and such. This particular question was actually a follow up question to an even more specific situation that an Autodesk agent was able to answer. I don't feel so bad for not finding results since the agent couldn't produce anything either; I was probably being way too specific with my search strings 😛
Just to be clear, I'm not trying to advocate piracy or circumvent legal use, that intent wasn't even mentioned in my post. I'm trying to avoid noncompliance by finding answers to specific circumstances. No need for the disapproving warnings.
Cheers
