Can someone point to where the download the Maya 2015 offline documenation ? I only found the 2014 documentation for download offline.
Solved by jessica.t. Go to Solution.
Hello!
Here is the Autodesk Maya 2015 Offline Product Help download. Here's an additional link to other Maya Help. I hope this helps! We're here if you have any other questions or needs. Thanks!
I assume you went to preferences > Help > Help Location, selected custom then pointed to the folder where the Maya 2015 documentation resides on your HDD, correct ?
