Hello
Im trying to get the diffuse map and normal map on seperate UV sets to both appear on an object in the viewport - is this possible?
Solved by mspeer. Go to Solution.
Hi!
Yes, this can be done.
You need 2 editors for this, the "UV Set Editor" to create the uv-sets and the "Relationship Editor" (UV-Centric) to assign the textures to different uv-maps. You can find them in the menu or right-click on an object and the go to UV Sets -> ...
