hotkey not working
hotkey not working
hotkey not working
Hello, I have a problem
With Maya 2016 Extenison2, the hotkey ctrl+w is not working. It can be assigned to a command (see screenshot), but the command is not working, nothing shows up in the script editor either. The command still works properly if chosen from the menu.
The same problem repeats on every computer of other users of Maya Extension2 I've asked, on any command, and doesn't repeat in previous extensions or in previous Maya versions.
I've been using this shortcut for this command for 11 years already, so please don't advise just to change it, it'd be too uncomfortable.
Here's what happens after I press a shortcut:
Here's what happens after I press it from the menu:
[SOLVED]
I'v found this video on Youtube usefull. This way will solve all issue. Smiley Very Happy
https://youtu.be/k2oKSU2ww8s
j_shelley
Does not work. Even after applying the duplicate hotkey settings to the Workspace.
Turns out that Ctrl+W is not a valid hotkey. It just plain does not work, for absolutely no reason whatsoever.
Either this should be fixed, or Maya should not let you bind it in the hotkey editor
alanlashbrook
Yes, I have had the same problem. Thanks for staying with this.
