When I load my rig I am no longer able to MMB click on a frame in the timeslider without the rig updating to the new position. This means that the "update false" flag for currentTime is somehow broken.
I cannot find out what I have done wrong, no how to debug this, but I assume that I have made some connections in the rig that forces a full update on time change despite the update false flag.
I am using a custom python plugin node for my rig and I guess that this could be the cause. However, even when deleting the node from my rig, the problem remains.
I would much appreciate any pointers on how to debug this or ideas for what could be the cause, as it is a feature that I use heavily when animating.
Cheers and thanks in advance
Solved by mspeer. Go to Solution.
That was exactly the hint I needed. Changing Evaluation Mode fixed the problem! Thanks 🙂
For good measures, I'm on Maya 2019
