This is my first time using these forums, so i apologize if i miss some of things i am supposed to say.
I am using a macbook pro, the yosemite os and maya 2016.
I am having an issue that i cannot find a solution for. An animation i am working on but whenever i play the animation (or just move the bar along the timeline), maya either crashes or freezes with a white box on screen. It happens at random but it always happens and I cant get anything done with this issue. Any help would be most appreciated.
Solved by tony.su. Go to Solution.
You can try to change evaluation mode to DG. There is an issue in Parallel mode.
Terribly sorry for this. I had forgotten that i need to accept a solution or something to close this thread. I am just going to accept yours as the solution. My friend figured out that their was something in the scene that was messing up the animation. Once i ditched it and worked on something else, it started working again just fine. i dont know what in the scene caused it to brake but i have since abandoned it. Any way, thank you for your reply and i apologize for my lateness for a response.
Maya 2018 is a shame. with animation interpolation on DG will don't freeze during animation, but will freeze anyway. Is absolutely imposible to have ncloth / nhair simulations in maya 2018. And guess what fbx export don't work to ! it change the position and the scale. I think I will go to blender or cinema 4d, maya destroyed my life. Ohhhhhhh and don't make me to talk about Xgen. Don't start me to do that. You will be shocked.
I dont know DG will be problem in the future but now, Im happy to solve that.
Thanks you to share
