Hi everyone,
I'm currently using Maya 2011 hotfix 2 and when trying to export skin weights maps, I get the following error : "Failed to export the attribute map".
Just wanted to know if I'm the only one having this rather annoying issue... export worked properly for me with the initial version of Maya 2011.
System specs:
Windows 7 Pro x64
Intel i7 920 @2.67Ghz
8 Go Ram
Quadro FX 4600
=================================Edit
I rolled back to the initial build of Maya 2011 (april) and I got the same error... It was working fine before I installed the hotfix 2...
And comet's scripts weight export tool gives me a syntax error...
I made tests with clean files, simply skinning a cylinder to a bunch of joints... no export possible.
Could my install be corrupted?
Kind of lost here... help...drawning...glups...
I'll be filling a support, but if anyone has an idea of where I could start searching, you're more than welcome :)
