Would anyone know where to locate the Offline Help installer for Autodesk MatchMover 2014?
The usual places to look yield know information ... well, at least none that I found.
Cheers,
* UPDATE *
Here are the details on App Exchange Portal version of MatchMover 2014.
Version (Cut ID): 201402270034-908670
Help Type: Website, no search, no index
The version included as part of the suite, post updates/patches:
Version (Cut ID): 201302190204-862496
Help Type: Local, search, index
Path to Help: C:\Program Files\Autodesk\MatchMover2014\Help\index.html
* UPDATE *
Partial progress on this one; firstly, one must contact technical support to obtain the MatchMover Offline Help (.ZIP). Unfortunately, there doesn't seem to be a method to switch MatchMover to look at the Local help folder as the application has been hard-coded to look at a specific website URL.
As of this note, technical support is still looking into it to see if some "override" exists ... in the interim, ordered sufficient tar and feathers for all of the MatchMover Dev Team.
