Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Matchmover not working, error 25
8 REPLIES 8
Message 1 of 9
1152 Views, 8 Replies
I just bought Maya 2013, yay!, but Matchmover is not working, is there a workaround other than copying the license.env to matchmover package content?
I have OSX Mountain Lion.
attached is the error
8 REPLIES 8
Message 2 of 9
I'm not entirely sure.
But, from my experience, all the licensing should be valid just from when you installed the Maya package. But, here's an issue I had, I could not run Maya and Matchmover at the same time, I always had to close one before I could start the other.
Is this the issue you're having, or can you not run Matchmover, period?
Message 3 of 9
Yes, I'm afraid that's the case.
I can't run it, period. With or without maya running.
Message 4 of 9
Is there anyone from Autodesk that knows the answer?
Thanks so much in advance.
Message 5 of 9
all the answer of your problem is here, but impossible to solve for the moment.this is a big bug on maya 2013 , matchmover don't work:
http://area.autodesk.com/forum/autodesk-maya/matchmoving/matchmover-not-starting-possibly-licence-pr...
Message 6 of 9
Steve_Curley
Better to use the "permlink" - they work better than those long ones.
http://area.autodesk.com/forum/t69981
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 7 of 9
Thanks all for the info!!!
Message 8 of 9
I am a student of Autodesk. I tried to get Matchmover 2013 to work myself. I got as far as loading the image sequence. I loaded lion000.jpg which is the first image and clicked details and got none.. I set the sequence options and camera settings per instructions. When I clicked play, I got a message saying "cannot open the following image sequence". That is as far in Matchmover 2013 I could get. If anyone finds the solution, would you please let me know? Thanks!
Message 9 of 9
I have experienced this too - can't load image sequence - the message box gives NO details as to why it can't load the sequence!
