See ncruz’s post at the top…
(He ‘is’ an Autodesk employee after all).
To run Matchmover you must have either Maya or 3dsmax installed. As an example. To run Matchmover 2011, Maya 2011 must be installed.
I have 3ds Max 2010 32-bit, 3ds Max 2010 64-bit, 3ds Max 2011 32-bit, and 3ds Max 2011 64-bit installed and licensed, however none of the MatchMover (2010 32-bit, 2010 64-bit, 2011 32-bit, and 2011 64-bit) installs from the subscription center will run. I get the splash screen and then the application disappears from the task manager. Because there is no .log file with the 3ds Max version of MatchMover there is no way to know what the cause is.
-Eric
7400 2011/02/07 15:41:04 Reason=Fatal error
7400 2011/02/07 15:41:04 ComputerName=<removed>
7400 2011/02/07 15:41:04 OS=5.2.3790.Service Pack 2
7400 2011/02/07 15:41:04 File=AdlmIntLicense.cpp,Line=613
7400 2011/02/07 15:41:04 VendorID=6
7400 2011/02/07 15:41:04 VendorError=16
7400 2011/02/07 15:41:04 File=AdlmIntLicense.cpp,Line=614
7400 2011/02/07 15:41:04 AdlmIntError=43
====== BEGIN MAYA LICENSE DIAGNOSTICS Mon Feb 07 15:41:20 2011 ======
623848 ::: 2
623905
623911
623907
623909
623801 ::: m2010.016 win64, built Mar 19 2010 04:05:31
623802 ::: links in AdLM but not Flint
623833 ::: 'adlm'
623858 ::: 'en_US'
623912
623913
623824 ::: MAYA_LICENSE_METHOD 'standalone'
623823 ::: MAYA_LICENSE 'adlm-128c1-2011.0.0.f'
623826 ::: MAYA_ALT_EN
623830 ::: MAYA_LOCATION 'C:/Program Files/Autodesk/MatchMover2011'
623866 ::: 'C:/Program Files/Autodesk/MatchMover2011/adlm/en_US'
623846 ::: AdLM 1.3.34.0 (D034) win64
623807 ::: standalone MA 128C1 2011.0.0.F
623109 --- MA 128C1 2011.0.0.F 43
623837 ::: 0
623834 ::: 0
623838 :::
623805 :::
====== END MAYA LICENSE DIAGNOSTICS Mon Feb 07 15:41:20 2011 ======
my MatchMover 2013 crashes on starting in windows 7(Service Pack - 1), it shows MatchMoverApp.exe has stopped working and nothing happens when i check online for a solution
I have same probelem, crash on start. Im using Maya 2013 with OSX.
OSX, Maverick,
Processor 2,6 GHz Intel Core i7
Memory 8 GB 1600 MHz DDR3
Software OS X 10.9.1 (13B42)
Graphic card:
NVIDIA GeForce GT 650M:
Chipset Model:NVIDIA GeForce GT 650M
Type:GPU
VRAM (Total):1024 MB
Thanks in advance for you help.
