#3ds max 2D track extractor v0.01 SAVAŞ ÇETİN
#Base code:MatchMover Perl Sample Scripts: NUKE Export (c) REALViZ 2004-2005
# parameters
#my $output_file = "c:/test.nk"; # exported file
my $output_file = $mm->showMessage( "This Perl script will export tracks of the current seqence to the program root directory as a maxscript file (*.ms):", -1 );
die "no output file" if ( !defined $output_file );
# helper to convert whitespaces to underscore
sub conformString
my $string = shift;
$string =~ s/ /_/g;
return $string;
# open output file
open( OUTPUT, ">", $output_file ) || die "couldn't open the file $output_file !";
## header data
print OUTPUT "-- REALViZ MatchMover Pro 3ds Max 2D track exporter output file by SAVAS CETİN \n";
print OUTPUT "-- version 0.01 \n";
#print OUTPUT "version 4.3020\n";
# get sequence/cameras settings
my &#xse;quenceAttribs = %{$mm->getSequenceAttribs( $mm->getSequenceId() )}; # attributes of current sequence
my $sequenceLabel = conformString( $sequenceAttribs{label} ); # sequence label
my $firstFrame = $sequenceAttribs{first}; # first frame
my $lastFrame = $sequenceAttribs{last}; # last frame
my ÊmeraAttribs = %{$mm->getCameraAttribs( $sequenceAttribs{camera} )}; # corresponding camera attributes
my $haperture = $cameraAttribs{fbw}; # film back width
my $vaperture = $cameraAttribs{fbh}; # film back height
my $numframes = $lastFrame - $firstFrame + 1; # nb of frames
my $height = $cameraAttribs{h}; # image height
my $input = $sequenceAttribs{file}; # input sequence filename
my $imagePlaneDepth = 100.0; # depth of image plane
my $label = conformString( $trackAttribs{label} );
# replace # and @ in input sequence name by corresponding printf pattern ( file.###.jpg ==> file. d.jpg )
my $hashcount = () = $input =~ /#/g;
$input =~ s/(#)+/%0${hashcount}d/g;
$input =~ s/@/%d/g;
# feedback to user
print "Exporting sequence '$sequenceLabel' to file '$output_file'...";
print OUTPUT " animationRange = interval $firstFrame"; print OUTPUT "f\t"; print OUTPUT "$lastFrame"; print OUTPUT "f \n";
#print OUTPUT "}\n";
# export all 2D tracks
# for all groups
my @groups = ( -1, @{$mm->getGroupList()} ); # add default group
foreach $group ( @groups ) # browse all groups
my $glabel;
if ( $group == -1 ) { # defaul group
$glabel = "Point_Tracks";
} else {
# collect info of this group
my &#xgr;oupAttribs = %{$mm->getGroupAttribs( $group )};
$glabel = conformString( $groupAttribs{label} );
my @tracks = @{$mm->getTrackList( $group )}; # collect all tracks of this group
# exports all tracks of the group
foreach $track ( 0..$#tracks )
my @track2Dinfos = @{$mm->getTrack2D( $tracks )}; # get track 2D positions
my &#xtr;ackAttribs = %{$mm->getTrackAttribs( $tracks )}; # get track attributes
print OUTPUT "$label = Dummy name:\"$label\" boxsize: \n"; # set Dummy name and size
print OUTPUT "animate on ( ";
print OUTPUT "\n";
foreach $t2Dinfo ( @track2Dinfos )
my &#xha;sh = %{ $t2Dinfo };
my $t = $hash{t} + $firstFrame;
my $y = $height - $hash{y} ;
my $u = $y / 10; # scale values
my $w = $hash{x} /10; #scale values
print OUTPUT "at time $hash{t}f $label.position = \n" ; #scaled values
#print OUTPUT "at time $hash{t}f $label.position = \n" ; #original values
##print OUTPUT "x$t $y \n"; ##
##print OUTPUT "x$t $hash{x} \n"; ##
print OUTPUT ") \n";
# close output file
close( OUTPUT );
