MapGuide Enterprise Wishes
Valued Contributor
kirsten77
Message 1 of 5 (205 Views)
Tooltip display from secondary table
205 Views, 4 Replies
07-16-2006 10:53 PM
Could the new version allow users to set the tooltip to display differently to the labels on the map?
Data from different tables?
*Andy Morsell
Message 2 of 5 (205 Views)
Re: Tooltip display from secondary table
07-17-2006 03:11 PM in reply to: kirsten77
The new versions (MapGuide Open and MapGuide Enterprise 2007) currently do
work that way. The tooltip information can be different than the label. I
haven't tried it yet, but in theory, your information should be able to come
from different tables since you are not limited to just one join per feature
source.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5238582@discussion.autodesk.com...
Valued Contributor
kirsten77
Message 3 of 5 (205 Views)
07-18-2006 04:08 PM in reply to: kirsten77
Does anyone know how I could do this then?
*Carl Von Stetten
Message 4 of 5 (205 Views)
07-19-2006 07:55 AM in reply to: kirsten77
It depends on the type of feature. We have worked around this
shortcoming of MG 6.5 with polygon features by creating two nearly
identical layers within a layer group. The first layer displays the
polygons with transparent background, and displays the desired tooltip.
The second layer is also transparent, has no edge display, and has the
desired labels displayed.
HTH,
Carl
*Andy Morsell
Message 5 of 5 (205 Views)
07-21-2006 12:19 PM in reply to: kirsten77
Have you tried this with MapGuide Enterprise 2007 or are you wanting to do
this with 6.5? If 6.5, then you are limited to the work-around that you
described in your post in the general discussion group that you have already
put in place.
Andy
wrote in message news:5240934@discussion.autodesk.com...
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
