Because SDF can store multiple geometry types, when I create a new layer from a SDF feature source, the new layer will have all 3 geometry styles, even if the SDF only has one type of geometry.
The only time a layer from a SDF feature source has a single geometry type style is if it was converted from a different format (eg. SHP)
Studio should be smarter about this, it should figure out that there's only polygons in it and so if I create a new layer from it. It will only have polygon styles. Not all 3 together!
Currently, the only way to change this is to manually edit out the useless styles in the layer document. And that is a time consuming process.
- Jackie
http://themapguyde.blogspot.com
http://au.linkedin.com/in/jackieng
