MapGuide Enterprise Wishes
Member
jpizzo
Message 1 of 1 (121 Views)
Better Text import W/ Rotation
121 Views, 0 Replies
06-25-2007 09:40 AM
MapGuide has always been weak at importing text.
I have to export to a database and import that to MapGuide
Please make it so I can use rotation when I import text directly from SDF or SHP.
When exporting text I try adding rotation as a property in the NAME or URL field, but MapGuide won't use it. Rotation should be automatically included when you export TEXT from AutoCad, just like X, Y, and String.
In addition to ID, NAME and URL a THEME column should be added to AutoCad Map when exporting to sdf or shp.
Also, Enterprise is painfully slow with layers connected to databases.
