Why does publisher not maintain the current zoom level when changing views? It most inconvenient having to zoom back in after changing a view. Is there anyway to maintain the zoom level?
Regards
Victor Pringle
Solved by dmjessup. Go to Solution.
Simple fix for you. Right-click on the cube in the upper right-hand corner. Select properties. Uncheck Fit to view on view change. OK and you're done.
I changed this and it works when using cube, but what about when I have views under keys 1, 2, 3 shortcuts? They apply fit to view and I don't want it. Can I change it there too?
P.S Its for Inventor not Publisher, didn't see that, but maybe fix will be the same for both
