Inventor Publisher
Inventor Publisher
29 Kudos
Post 1 of 6
Will not import from Vault
589 Views, 5 Replies
12-12-2012 05:22 AM
I get the following message wheen trying to import from Vault:
Failed to complete the vault command 'Insert From Vault'. - The process can not access the file, because it is being used by another process.
I am the only person using Publisher, but the file is almost constantly used by someone in Inventor.
How can I fix this?
29 Kudos
Post 2 of 6
Re: Will not import from Vault
12-13-2012 03:32 AM in reply to: bowen192
I'm quite keen on speaking to someone from Autodesk about this, as I'm currently at a work stop.
29 Kudos
Post 3 of 6
12-14-2012 05:56 AM in reply to: bowen192
Now my projects have stopped opening:
29 Kudos
Post 4 of 6
12-19-2012 08:31 AM in reply to: bowen192
Sorry to interupt the Autodesk Christmas party, but I am still having problems.
I can now import a file from Vault and save in to Vault.  However, I cannot open it and get the following:
29 Kudos
Post 5 of 6
12-20-2012 12:48 AM in reply to: bowen192
Alright, alright.
I don't even want an answer any more, just a response, anything just to aknowledge Autodesk recognise there may be a problem.
Cheers.
Employee
1 Kudo
Post 6 of 6
12-20-2012 09:39 PM in reply to: bowen192
Hi ,
would you please try insert this inventor file from local folder?  we will then investigate what is the issue.
publisher has a local folder mapped to vault folder, when insert from vault, it will download files to local folder.
Leo
