Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Why doesn't autoexplode separate components in a straight line of disassembly?
2 REPLIES 2
452 Views, 2 Replies
How can I get auto explode to assembly pulled apart components to remain in the line of disassembly, rather then showing the part off to the side?
2 REPLIES 2
Jon.Balgley
Unfortunately, the auto-explode command does not give you this kind of control -- it is quite limited.  You may have better success with the "manual explode" command.  This lets you select a set of components and "pull" them along an axis.
Jon Balgley
in reply to: Jon.Balgley
Maybe this is an issue that can be addressed in the next release?  If there is no software solution for a correct auto exploded view and I would need to manually pull apart each component, why would a customer spend $2400 on Inventor Publisher to manually explode an image when your Design Review software does the same for 0 dollars?  I would think that's the reason for spending the $2400...to get the automation needed to auto explode to reduce the cost of equipment manual production.
