Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Vector export
1 REPLY 1
Tiziano3630
372 Views, 1 Reply
Vector export
Hello All,
Does anybody has an explanation why it sometimes takes a long time to translate a Ipb snapshot into vector (.svg) format. Sometimes the time to translate a snapshot is 10 to 15 minutes.
Tiziano
1 REPLY 1
Hello Tiziano,
Do you mind sharing this particular dataset? You can email it to me rajkumar.ilanchelian@autodesk.com. IF the file is huge then maybe you can send it via dropbox? We are not aware of any performance issues regarding vector output and a dataset would be huge to test and track the issue.
Also you mentioned that "sometimes" it takes a long time. Is it the same snapshot that exhibits different time behavior?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
