Inventor Publisher
Inventor Publisher
Valued Contributor
16 Kudos
Post 1 of 3
Turn off Shiny Appearance
285 Views, 2 Replies
03-12-2012 12:36 PM
     I inserted a 3D assembly into a new Publisher document.  The component parts are retaining their "Shininess" setting from Inventor.  I would like to modify or turn off the shininess setting when the model is in my Publisher document.  Even when I change the color of a part, the shininess stays the same.  Is it possible to turn off the shininess of a part?
Daniel Hermanson
Spraying Systems Co.
Hi Daniel -
The "Shininess" you are seeing must be the result of the material you have applied to the part in Inventor. If you want a less shiny surface, you can change the material of any part from within Publisher. Simply changing the color will not modify the material applied, just the rgb value applied to that specific material.
To change the material of a part, right-click within the authoring environment and select "Material". This launches the Material marking menu (where you have tried to changed the color already). There is a blue square at the top of the marking menu that will drop down a list of basic materials, as well as an option to launch the Autodesk Material Library. From here you can assign any material you'd like.
Timera
Employee
21 Kudos
Post 2 of 3
Re: Turn off Shiny Appearance
03-22-2012 10:18 AM in reply to: dherman469
Hi Daniel -
Timera
Valued Contributor
16 Kudos
Post 3 of 3
03-22-2012 10:20 AM in reply to: TimeraAutodesk
Thanks, Timera.  That works.
Daniel Hermanson
