When turning on trails, I select all parts and subassemblies (not the main component that is not moved) and right-click and turn on Trail Visibility. Only the trails for the parts are displayed. I have to individually window select the subassemblies to turn on their trails. Am I missing a way to turn on the visibility of trails for parts and subassemblies in one operation?
Dan
You could select them from the browser and turn on trails in one operation. Window select should work as the same way. So after you window select parts and sub-assembly, do you check if they are what you want from the browser?
-Dave, Publisher developer
