Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Toggle on/off callout Pin to Screen
1 REPLY 1
mthomas
329 Views, 1 Reply
What would be very, very nice is some method to toggle on and off "Pin to Screen" for all callouts in a snapshot. In most cases I want the callouts pinned to the screen but there are times were I just want to adjust the view, say slide the assembly over (pan)... it would be nice to hold a key which would temporiryly set all callouts not pinned to the screen, do my view manipulation and then let go of the button reverting the callouts back to pinned to screen
Mike Thomas
1 REPLY 1
Hi Mike,
Thanks for the enhancement suggestion here. I will let our development team know about this enhancement request.
Below is a solution that may make this workflow a little bit easier (by no means it is a hold button straightforward workflow)
1. Create a selection set of all the callouts
2. When you want to turn off pin to screen
       i. Select the selection set
      ii. Turn off pin to screen
3. When you are done
      ii. Turn on pin to screen
Like I mentioned not exactly what you are looking for but could help make the workflow a little more easy.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
