Hello!
I've been trying to decide how I am supposed to publish my welding instructions.
When I tried to publish it as a Word-document, my instructions didn't look the same. The different snapshots were changed and the ""Detail View"-bubbles were gone. There were pictures of the transitions and odd views.
Is there a way to publish my instructions as is in Publisher when I create it?
Kind regards,
Gisela Svensson
Technical Communicator
Not sure 100%, but I would look at the following;
Which version of Word are you using? I find 2010 gives best results.
When you selct Publish > Microsoft Word, make sure Scale Annotations is NOT checked.
Is the Print Area Setup the correct size?
It should be perfect. What else isn't quite right?
You can of course create your own Word templates.
You're not the first to make the comment that Publisher feels as though it has been forgotten. There are a lot of frustrated people using the software and not much in the way of answers from Autodesk.
I get the impression that Autodesk have done quite a large overhaul for the next revision though. We can only hope they've listened to the comments that have been made on here.
