Inventor Publisher
Valued Contributor
michael.shelley
Message 1 of 5 (206 Views)
Styles Issue
206 Views, 4 Replies
03-31-2011 11:05 AM
Guys,
I am in the middle of a very fustrating problem. I have set up a publisher document with many snap shots showing various views and details. I had set up each view with slightly differt styles. (technical line drawing, ghost, shaded, gray scale etc..).
Now I can't change the styles back to what I had originally. I have tried everything. Can anyone help me on this?
Thank you in advance!!
Michael
Board Manager
Jon.Balgley
Message 2 of 5 (201 Views)
Re: Styles Issue
03-31-2011 05:01 PM in reply to: michael.shelley
Try this:
  • Select the root (or highest level assembly of interest) in the browser on the left.
  • In the styles command (gallery) select "Clear Style"
That may work.  If it doesn't work, try:
  • area-selecting all the components (drag-rectangle-select)
  • Then do Clear Style
If that doesn't work then try to select all intervening sub-assemblies (one at a time, for a start), and do Clear Style on them.
Let us know if any of those work.  Sorry it's not easy.
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Valued Contributor
michael.shelley
Message 3 of 5 (194 Views)
Re: Styles Issue
04-01-2011 12:35 AM in reply to: Jon.Balgley
Tried all of these things. And nothing!! It now looks like I have to make a new publisher document. Now I'm a little afraid of using styles. Unless you can suggest something else?
Using publisher 2012 by the way.
Michael
Board Manager
Jon.Balgley
Message 4 of 5 (186 Views)
Re: Styles Issue
04-01-2011 11:55 AM in reply to: michael.shelley
Can you send me the IPB file?  Or a representative sample?
Email to jon.balgley@autodesk.com
Thanks, and we'll try to help!
Jon Balgley
bowen192
Message 5 of 5 (176 Views)
Re: Styles Issue
04-04-2011 01:37 AM in reply to: michael.shelley
I don't know if this helps but I had a simalar problem and found a workaround.
I found that I could not change the style of a complete assembly if I'd already done it once already.
My workaround is to select a single component, invert the selection and then change to the desired style.  Select the original single component and change that to the desired style.
Hope this makes sense.
