Inventor Publisher
Member
a_angel
Message 1 of 2 (583 Views)
Storyboard Batch Image Output
583 Views, 1 Replies
08-31-2012 07:34 AM
Is it possible to output all of the image files from a storyboard with one command?
Currently I have 12 images showing how to dissassemble an assembly. All the images will be output with the same options, I just don't want to waste time outputing the 12 images seperatly.
Thanks in advance
Yes it is possible,
In the output image select the storyboard option instead of snapshot.
That should do the trick.
Active Member
documentation
Message 2 of 2 (582 Views)
Re: Storyboard Batch Image Output
08-31-2012 11:42 AM in reply to: a_angel
Yes it is possible,
