Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Snapshot without picture in word
3 REPLIES 3
Timmy_Stalnacke
674 Views, 3 Replies
Is it possebly to publish a word document without picture?
i have created a couple of storyboards that only contains text.
and when i publish to word there will be one snapshot per page with a blank picture in on the snapshots that only contains text.
I have tried to reduce the size of the picture but it don't make any diffrents.
Best regards
Timmy
3 REPLIES 3
LeoWan
in reply to: Timmy_Stalnacke
Hi ,
   What does you mean "storyboards that only contains text"? is that all model are invisible and just storyboard description text and snapshot description text
or  all model are invisible and just Label textbox on canvas?
if is the first case, you can customize the word template to remove the picture placeholder.Thus all snapshots will have only text without picture.
if is the second case, it cannot be reached.
Publisher QA
Timmy_Stalnacke
in reply to: LeoWan
Hi Thanks for the answer.
i mean as you mentioned in the second case. i want to mix pictures and text.
Thank you for posting your problem in Newsgroup. Could you try to set different publish area on different snapshot? If there is one snapshot doesn't contains model, please edit the Publish area and make it small. When publish to word, it will publish the Publish area by default for each snapshot.  See my attached image. Hope this workaround can solve your problem.
Peggy Wang
Sr. Software QA Engineer
Publisher Quality Assurance Team
Autodesk, Inc.
