Inventor Publisher
Inventor Publisher
Active Member
Andre2099
Message 1 of 5 (125 Views)
Silhouette Control Stuck?
125 Views, 4 Replies
04-02-2012 07:38 PM
I lost control of the Styles function.
Is this a known bug?
It wasnt like this earlier in the day.
Sometimes it lets me change a part's style, sometimes not, sometimes it will let me only change the internal edges but not the silhouette (stuck at 2 width, color black). It most certainly stopped letting me change styles of the top level part. It definately doesnt let me change anything in the canvas, only on the components menu.
I have parts stuck on "Subdued Line Drawing" and others stuck on "Clear", and other with a permanent silhouette. This is very frustrating.
Is there a fix for this? Whats going on? I
Active Member
Andre2099
Message 2 of 5 (124 Views)
Re: Silhouette Control Stuck?
04-02-2012 07:48 PM in reply to: Andre2099
Ok I started a new file and inserted a model in and it seems to work just fine. But when I go into my other file (which i've spent 3 hours on) it wont let me mess with styles anymore. So tells me something happened to my .ipb file. Whats up with that? Can one of you guys figre it out for me?
Its absolutely out of the question for me to start all over again on this project, I need to know how to fix what I have.
Employee
kumarra
Message 3 of 5 (113 Views)
04-03-2012 07:18 AM in reply to: Andre2099
I assume you are on service pack 2, and this provides access to old versions of the file (the last 10 versions) in the same location where your file is located. Can you check to see if any of the older versions works correctly? Also would it be possible for you to send me the problem ipb to rajkumar.ilanchelian@autodesk.com? If the file is more than 10MB please email me and I will send you a dropbox request.
Rajkumar
Active Member
Andre2099
Message 4 of 5 (108 Views)
04-03-2012 02:51 PM in reply to: Andre2099
Email sent
Employee
kumarra
Message 5 of 5 (92 Views)
04-04-2012 11:00 AM in reply to: Andre2099
Hello Andre,
Thanks for sending in the file. Having the file definitely help J. I believe I know what the problem here is and let me take a shot at explaining what is happening here:
  1. The simple rule is that the style applied directly ON the component wins
  2. If there is no style applied on a component it picks up the style from its immediate root component in the tree
With these two rules, you can now run down your snapshots and it will start unfolding why certain styles works and certain styles “appear” not to work.
I have sent a more detail email to you stating out examples from the file that you sent me. Please let me know if this helped clear the problem.
Rajkumar
