Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
rotation around center of hole.
3 REPLIES 3
OTH
Observer
2042 Views, 3 Replies
Hi, im trying to set up an animation of a torque wrench tightening a bolt.
problem is i cannot find out how to set the rotation axis accuratly at the centerline of the bolt (or any central axis that is not a physical line)
3 REPLIES 3
bowen192
in reply to: OTH
Click the bolt
Click the Move component
Holding Ctrl, select the wrench (if it's more than one part, use the canvas)
Rotate away!
Tags (4)
OTH
Observer
in reply to: bowen192
Thank you, this solved my broblem,
but i am curious if there would be a solution to this if there were noe bolt to rotate around? is there no way to set rotation axis around the centerline of a hole?
bowen192
in reply to: OTH
If you select an object with a hole, say a nut, the Move component will automatically align to the centre of the nut.
Don't forget, you can chose any object on your model to align your axis to.
