Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
rotation around center of hole.
3 REPLIES 3
2052 Views, 3 Replies
Hi, im trying to set up an animation of a torque wrench tightening a bolt.
problem is i cannot find out how to set the rotation axis accuratly at the centerline of the bolt (or any central axis that is not a physical line)
3 REPLIES 3
bowen192
Click the bolt
Click the Move component
Holding Ctrl, select the wrench (if it's more than one part, use the canvas)
Rotate away!
Tags (4)
in reply to: bowen192
Thank you, this solved my broblem,
but i am curious if there would be a solution to this if there were noe bolt to rotate around? is there no way to set rotation axis around the centerline of a hole?
bowen192
If you select an object with a hole, say a nut, the Move component will automatically align to the centre of the nut.
Don't forget, you can chose any object on your model to align your axis to.
