Hi, im trying to set up an animation of a torque wrench tightening a bolt.
problem is i cannot find out how to set the rotation axis accuratly at the centerline of the bolt (or any central axis that is not a physical line)
Solved by bowen192. Go to Solution.
Thank you, this solved my broblem,
but i am curious if there would be a solution to this if there were noe bolt to rotate around? is there no way to set rotation axis around the centerline of a hole?
If you select an object with a hole, say a nut, the Move component will automatically align to the centre of the nut.
Don't forget, you can chose any object on your model to align your axis to.
