Hi All
I've a saved selection of 3 parts. When I select that saved selection (shown in blue), the triad is orientated as it is shown below. I want to reorient the triad around 'A' (bolt, washers, bearing). For the life of me, I can't figure it out.
I 've selected 'reorient triad', selected the axis which I want to rotate about, then selected the part that I want to rotate about. It's not working OR it's not working how I'd expect..
Can somebody shed any light on where I might be going wrong?
Thanks in advance
CTS2013
Solved by bowen192. Go to Solution.
Reorient triad is not supported in Inventor Publisher currently if I undertand what you want to do correctly.
This requirement is well noted for future developmet of Publisher. Thank you!
-Huan
I've just figured out what you mean!
Save the selection.
Select the item you want to orientate around.
Select the Move tool.
Shift + Select the selection.
Is that right?
I forgot to add that you can Ctrl + click on the item you have selected to rotate around to stop that item moving as well.
