Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Reorient triad
6 REPLIES 6
780 Views, 6 Replies
Reorient triad
triad.jpegHi All
I've a saved selection of 3 parts. When I select that saved selection (shown in blue), the triad is orientated as it is shown below. I want to reorient the triad around 'A' (bolt, washers, bearing). For the life of me, I can't figure it out.
I 've selected 'reorient triad', selected the axis which I want to rotate about, then selected the part that I want to rotate about. It's not working OR it's not working how I'd expect..
Can somebody shed any light on where I might be going wrong?
Thanks in advance
CTS2013
6 REPLIES 6
Huan.Yu_Autodesk
Reorient triad is not supported in Inventor Publisher currently if I undertand what you want to do correctly.
This requirement is well noted for future developmet of Publisher. Thank you!
-Huan
bowen192
Just click Toggle Triad.
Happy days!
bowen192
I've just figured out what you mean!
Save the selection.
Select the item you want to orientate around.
Select the Move tool.
Shift + Select the selection.
Is that right?
in reply to: bowen192
Thanks - I will try this and report back.
Bingo!
Thanks bowen192
bowen192
I forgot to add that you can Ctrl + click on the item you have selected to rotate around to stop that item moving as well.
