Inventor Publisher
Valued Contributor
stevenguy
Message 1 of 5 (292 Views)
Publisher Browser Icon????
292 Views, 4 Replies
08-19-2011 06:52 AM
I still using IP 2011 R1 and I never see these icon before.
Can any one tell me what those icon mean and how to clear them.
See the attached picture
Steve Nguyen
CAD Admin/ Eng
Inventor Pro, Inventor Publisher & Vault 2012
Intel(R) Xeon(R) CPU X5690 @3.47GHz (2 processors)
Mem 48.0 GB
OS Win 7 64-bit
Graphic Card: Quadro FX 4800
Steve,
You are right. The files that have the X means that the file has been deleted. The other icon means that this particular component has been changed. The * icon means these components did not go through any change.  All these icons are temporary after an Inventor update. They should go away once you save the IPB file. Do they?
Employee
rajkumar.ilanchelian
Message 2 of 5 (290 Views)
Re: Publisher Browser Icon????
08-19-2011 07:43 AM in reply to: stevenguy
Steve,
Did you do a update to the Inventor assembly that you inserted in to Publisher? This is an icon that tells you which components were updated/deleted. These should how ever go away on ipb save. Do you still see them after a save?
-Raj (Autodesk)
Valued Contributor
stevenguy
Message 3 of 5 (288 Views)
08-19-2011 07:48 AM in reply to: rajkumar.ilanchelian
I did many time and the update go thru ok.
I think the icon that has the X infront that is the file that I deleted from Inventor.
The file icon has the pen infornt I think it need update and I try update the file many time but it not go away.
the other icon has * infront I am not sure what is it yet.
P.s I think if I use the IP 2012 then I can replace the file with another file then this issue may go away.
IP 2012 has the feature to replace the existing file with another file from another location.
This replace feature is good and it work better than update.
Steve Nguyen
CAD Admin/ Eng
Mem 48.0 GB
OS Win 7 64-bit
Employee
Message 4 of 5 (283 Views)
08-19-2011 08:14 AM in reply to: stevenguy
Steve,
-Raj (Autodesk)
Valued Contributor
stevenguy
Message 5 of 5 (280 Views)
08-19-2011 08:20 AM in reply to: rajkumar.ilanchelian
After I hit save the file then all icon back to normal and the deleted file with an X all gone and the IP file look the same as the Inventor .iam
Thanks for helping
Steve Nguyen
CAD Admin/ Eng
Mem 48.0 GB
OS Win 7 64-bit
