Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Publisher 2015 Bugs
3 REPLIES 3
542 Views, 3 Replies
Publisher 2015 Bugs
Lets kick it off.
Corresponding item highlighting on the model storyboard when hovering over an item/ part number on the component list is gone! However if you do it the other way round and hover over the storyboard then it will show in the component list. Was never a problem in previousSmiley Surprised
Same as raised by Bowen192 thread I presume: Opaque blue highlight missing
3 REPLIES 3
na.miao
hi,
Thank you for reporting this.
I guess they are same issue.
You can try these steps to see if it can resolve your problem:
  1. Close publisher 2015.
  2. Locate to C:\Users\<username>\AppData\Roaming\Autodesk\Inventor Publisher 2015\en-US
  3. Edit this xml file: “Catalyst-Settings-Display.xml”
  4. Change this line to:  <MaxDXLevel>9</MaxDXLevel>
  5. Save the file
  6. Launch Publisher and try again
if you can't resolve your issue, please contact us again.
Thank you
Na Miao(Autodesk)
Inventor Publisher QA
Yes. That fixed it. But a xml edit/change is a worry though for a new release.
Huan.Yu_Autodesk
Thank you for letting us know this solved your issue. This issue has been tracked in our internal issue tracking system and we will provide a better solution in the future. Thanks.
-Huan Yu
