Inventor Publisher
Inventor Publisher
ben.toms
Message 1 of 15 (435 Views)
Publisher 2013 - Ribbon Appears on 2nd Monitor
435 Views, 14 Replies
04-03-2012 07:01 AM
I've just installed Publisher 2013 running a dual monitor setup (Nvidia Geforce GTS450 with 296.10 driver) and for some strange reason the ribbon appears on the 2nd monitor, while the application is running on the 1st monitor. Does anyone know how to rectify this please?
My current workaround simply involves dragging each part of the ribbon back onto the 1st monitor so that it is no longer parked in the normal position.
Thanks in advance
Ben
Employee
kumarra
Message 2 of 15 (433 Views)
Re: Publisher 2013 - Ribbon Appears on 2nd Monitor
04-03-2012 07:33 AM in reply to: ben.toms
Hello Ben,
Right click on the ribbon and select reset ribbon. Does this solve your issue?
Rajkumar
ben.toms
Message 3 of 15 (425 Views)
04-03-2012 08:31 AM in reply to: kumarra
Hi Rajkumar,
Unfortunately not. I tried it and it just sets it back to the 2nd monitor.
Regards
Ben
bowen192
Message 4 of 15 (401 Views)
04-10-2012 06:42 AM in reply to: ben.toms
Thanks in advance
Ben
I am having this problem too.
Employee
TimeraAutodesk
Message 5 of 15 (393 Views)
04-10-2012 01:30 PM in reply to: bowen192
Thank you both for letting us know of this issue. We are working to resolve it in a timely manner.
Thank you,
Timera
ahollingshead
Message 6 of 15 (384 Views)
04-11-2012 08:29 AM in reply to: TimeraAutodesk
I have the issue too
Valued Contributor
dherman469
Message 7 of 15 (340 Views)
05-09-2012 06:24 AM in reply to: TimeraAutodesk
     I just installed Publisher 2013 and I am also having this problem.  I found a work around that works pretty well.  Don't maximize the program window on the monitor 1.  Instead, simply stretch the program out so that it mostly covers the whole monitor 1.  The ribbon tends to stay in the proper place when it is not maximized.
Daniel Hermanson
Spraying Systems Co.
kwilsonamerex
Message 8 of 15 (302 Views)
06-04-2012 05:43 AM in reply to: dherman469
Hello, We also installed all of our 2013 products and noticed this same thing happening on Publisher as well as Fusion 2013. It would be nice if we could have the option to dock the ribbons or leave it 'floating' for the other monitor. We are running a minimum of 2 monitors on user machines. Thanks for looking into this!
Kenny
Corsair 900D ♦ ASUS Maximus VI Extreme ♦ i7 4770k ♦ (3) GTX 780 Ti's ♦ Trident X 32GB ♦ Samsung 840 Pro ♦ WD 1TB Black ♦ SG 1TB ♦ Corsair H100i ♦ Corsair AX1200i ♦ many SP120's
PDS 2014 ♦ Vault 2014 Pro ♦ CFD 2014 ♦ Bunkspeed Pro 2014 ♦ Octane Render ♦ Certified Autodesk Inventor Professional ♦ CAD Manager/Design Engineer
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
Member
lance.stevens.ecad
Message 9 of 15 (267 Views)
07-11-2012 10:04 AM in reply to: ben.toms
Any update on this?  I have several clients with this issue.  With a great number of Inventor users using a dual monitor setup, here's to hoping a fix is seriously being looked into.
Employee
TimeraAutodesk
Message 10 of 15 (263 Views)
07-11-2012 10:30 AM in reply to: ben.toms
Hi Ben,
Thanks for your post. Yes, we are *actually* working on a solution for this, rest assured. In the meantime, the simple workaround that Daniel provided in this thread works well. Simply refrain from maximizing the Publisher window in the 2nd monitor, and stretch the window to meet your monitor size instead. This keeps the ribbon and all of it's components in place.
Happy Publishing,
Timera
