Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Publisher 2013 Help
0 REPLIES 0
Message 1 of 1
TimeraAutodesk
422 Views, 0 Replies
Publisher 2013 Help
Hi All -
You may have encountered an issue with the Publisher help link, which is intended to point to WikiHelp
There is a simple fix that can be used immediately until the issue is more permanently solved:
Edit the HelpConfig.xml file that is installed at C:\Program Files\Autodesk\Inventor Publisher 2013\Help and change the <OnlineUrl> value from “http://wikihelp-stg.autodesk.com” to “http://wikihelp.autodesk.com”.
Please don't hesitate to contact me via the forum or directly at timera.hart@autodesk.com with any questions/concerns.
Thanks for your patience,
Timera Hart
0 REPLIES 0
