Inventor Publisher
Inventor Publisher
Active Member
1 Kudo
Post 1 of 2
Publish to 3D PDF - List of Field Tags
280 Views, 1 Replies
06-27-2012 09:44 AM
Greetings
I'm creating a custom template for publishing a 3D PDF from Publisher 2013.
The help documentation refers to:
Storyboard Tags
  • Storyboard\Number - Displays the storyboard number when called in a template.
  • Storyboard\Name -Displays the storyboard name when called in a template.
  • Storyboard\Description - Displays the storyboard description when called in a template.
However these seem to be only for 2D PDF publishing (trying them for 3D PDF does not seem to work).
The only 3D PDF ones I seem to have found are from the template already availble in the templates folder.
The Tags are:
Play_All
Next
Previous
First
Last
Description
Is there a full list of support tags anywhere for publishing to 3D PDFs?
Many thanks
Vince
Employee
21 Kudos
Post 2 of 2
Re: Publish to 3D PDF - List of Field Tags
07-02-2012 08:50 AM in reply to: vince480
Hi Vince,
Thanks for your post. 3D PDF does not support annotations or storyboard title/descriptions, so that is why you aren't seeing those tags as available. The only outputs that currently support the publish of these Title and Description fields is Publish to Mobile (.ipm) and Publish to Flash. Publishing to 3D PDF will only give  you the ability to play the animation and manipulate it in 3D space.
We are pursuing other solutions for this disconnect, so please stay tuned, but for now those are the available options.
Timera
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
