i have the same question about the inventor publisher. We have a inventor suite 2010 for edu. I applied the 30 days trial of the inventor publisher 2011. but i can not find the publish to mobile. where is that function part?
Hello, Pardon the slow response. If your trial is of the 2011 R1 version (with a airplane propeller on the box), then you should see Publish to Mobile as an option along with all the other Publishing outputs. Perhaps you have the original 2011 trial that did not include Publish to Mobile. You can get a 30day trial download of the 2011 R1 from www.autodesk.com/inventorpublisher
Best regards,
-Sam
I have created an ipm and published it to mobile. It contains a section view (unfortunately limited options for sectioning in Publisher), which does not render when viewing on ipad or iphone. Is this due to a hardware issue with the mobile devices?
Has anyone else managed to view a section view on ipad/iphone or had similar problems?
