An Inventor Publisher storyboard published to DWF experiences a viewing problem when opened in Autodesk Design Review 2012. The file opens and zooms to the center of the assembly. It begins to play the assembly instruction, but you can't see what is happening because of the zoom level.
No zoom option will fit the assembly to the window and maintain that magnification.
Has anyone else experienced a similar problem?
- I have tried DWF and DWFx.
- I have tried Design Review 2011 and 2012
Both DWF and DWFx experience the same "zoom to center of assembly" issue.
I have attached a published DWF created from the sample "Pro Series Brake Rotor" included with Inventor Publisher 2012 for others to review.
Thank you for your time and attention. I look forward to your replies.
Best regards,
Jerry Berns
Hi Jerry,
Our development team has found the cause of this issue and we have a fix that we are testing.
Sorry for the inconvenience caused.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Thank you for the update, Rajkumar. I look forward to hearing of your success.
Best regards,
Jerry
