Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Problem with custom Word Template in Inventor Publisher 2013 R1
6 REPLIES 6
642 Views, 6 Replies
I have problem with custom template in Word. When I input Smart tags in new Word template, Inventor Publisher did not recognize the word document.
I used Word 2013. When i used copy default Word document in Inventor Publisher, it is work, but  when I delete all tags and input new in default Word template in Inventor Publisher i have same problem. How to fix that problem?
6 REPLIES 6
I got the same problem... How do you fixed it? Thx. C y
I was not able to solve. We are left to wait Autodesk Inventor Publisher
2015.
Best regards.
jannaspicer
Hi there,
I'm sorry to hear that the 2013 R1 version is causing you trouble.  But I do have some good news: The wait is over... Inventor Publisher 2015 is now available. You can get a free trial here.
In the mean time, we'll see if we can reproduce the issue you're experiencing with Word, and let you know what we uncover.
Janna
in reply to: jannaspicer
Hey there, Well... I have a bad News about the version... I'm using a 2015 version... and btw... I Got the same problem... Anyway, I will search for some tutorial in youtube to find a new way (correct way) to fix it. Thx Wesley
Thank you very much for your answer. I'll try to solve the problem with the new version.
Best Regards
Huan.Yu_Autodesk
Hello Everyone,
Thank you for reporting the issues to us. For customize word template, here is some more info for you:
1, As you know, Inventor Publisher provides two word templates in C:\ProgramData\Autodesk\Inventor Publisher 2015\Templates\Word\en-US
You can customize your template based on these two docs.
2, As for how to defines the tags with the content control, please see the info here:
http://nikpatel.net/2010/04/11/add-content-controls-in-the-word-documents-for-the-open-xml-automatio...
3, Please note in order to create a valid template, the template file should at least contain any one of these tags: Storyboard, Snapshot and Transition. Otherwise, Publisher will treat it as invalid template.
Please let us know if you have more questions. And if you still meet problem to customize your template, please attach your template here or send it to us: publisher.support@autodesk.com. We will take a look at it for you.
-Huan Yu
