Inventor Publisher
Active Contributor
jahed.ali
Message 1 of 2 (127 Views)
Problem in showing hidden objects
127 Views, 1 Replies
05-23-2012 11:30 PM
When I move my mouse on the screen it shows hidden objects like screws in the body of an object.
It is like blinking. Same problem is happening during playing the storyboard.
Employee
TimeraAutodesk
Message 2 of 2 (116 Views)
Re: Problem in showing hidden objects
06-01-2012 08:08 AM in reply to: jahed.ali
This is due to a performance issue with your video card. Please ensure you are using the latest drivers. In particular, Nvidia cards have the biggest problems in this area we have noticed.
If updating your driver doesn’t work, you can work around the problem by disabling the performance optimization that exposes the bug:
In the file %userprofile%\AppData\Roaming\Autodesk\Inventor Publisher 2013\en-US\Catalyst-Settings-Display.xml change the line “<DisableRetainedRenders>false</DisableRetainedRenders>” to “<DisableRetainedRenders>true</DisableRetainedRenders>”
The “%userprofile%” should be typed in to explorer or whatever literally as it will be translated by the system to their “home” directory.
- Timera
