Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Opaque blue highlight missing - 2015
6 REPLIES 6
bowen192
1014 Views, 6 Replies
When I click on an object, the opaque blue highlight does not show up.
Is this just me or is anyone else having this problem?
6 REPLIES 6
na.miao
in reply to: bowen192
hi,
Thank you for reporting this issue.
Maybe it is caused by your graphic card  is lower than the product required.
You can try these steps to see if it can resolve your problem:
1. Locate to C:\Users\<username>\AppData\Roaming\Autodesk\Inventor Publisher 2015\en-US
2. Edit this xml file: “Catalyst-Settings-Display.xml”
3. Change this line to:  <MaxDXLevel>9</MaxDXLevel>
4. Save the file
5. Launch Publisher and try again
Na Miao(Autodesk)
Inventor Publisher QA
bowen192
in reply to: na.miao
In C:\Users\<username>\AppData\Roaming\Autodesk there does not appear to be a Inventor Publisher 2015. Only 2012, 2013, 2013 R1 etc.
na.miao
can you tell me your OS? maybe different OS has different path
Na Miao(Autodesk)
bowen192
I am using Windows 7.
I have located the folder now but there appears to be no Catalyst-Settings-Display:
na.miao
hi,
  please close publisher and go to the folder again, all of the xml files are created after you start and close it after  launch publisher at the first time.
thank you
Na Miao(Autodesk)
bowen192
That sorted it. Smiley Happy
Thanks for your help.
We want more of this from Autodesk!
