Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Multiple views on 1 sheet
4 REPLIES 4
PACDrafting
774 Views, 4 Replies
Is it possible to place multiple views on 1 sheet?
Paul
4 REPLIES 4
bowen192
in reply to: PACDrafting
You can using callouts.
Is this what you're after?
PACDrafting
in reply to: bowen192
Thanks for the reply.
However this is not what we are after.
As an example: If say a front view is placed in. Can you then place a view from the side?
Regards
Paul.
bowen192
In terms of something being a single click away, then no.  There is a workaround however:
Click Detail View
Cick anywhere on your model and then click again where you want to place the second image.
Change the Scale to 1x
Double click the detailed view (Annotation).
Re-size the detailed view so it shows the whole tool.
Click Return.
Re-size the Annotation so it encompasses the whole model.
Remove the Outline border and any Shape or Leader which may be left over.
Un-check the Lock Aspect Ratio and Lock Focal.
Move the original model to the desired position.
You can of course do this multiple times and lock the position of each image with the Lock Aspect Ratio and Lock Focal.
It does take a bit of planning becasue you have to create your first view last, if you see what I mean?
Hope this helps.
peggy.wang
Cool.
Peggy Wang
Sr. Software QA Engineer
Publisher Quality Assurance Team
Autodesk, Inc.
