Good Morning,
One of my users as this program installed, however he does not get the "mini toolbar" when selecting objects.
I've tried to look this up online and it doesnt seem as if there is a way to turn the mini toolbar on or off. If that is the case, how can i get it back?
Can you please be a little more specific as to what you are referring to as the mini toolbar?
If you go to the view tab and look at the navigation panel you have options to turn on/off view cube and the navigation bar. Also a right mouse button on the ribbon will give you access to a "reset ribbon" that will put the ribbon to the default. Also next to the view tab there is a dropdown that lets you cycle through various options where the ribbon can be minimized to tabs, panel titles etc.
If what you are referring to is none of the above please try to attach an image that explains the issue.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Sorry for the bad description. I dont use this program.
But by googling it i came across this link:
http://inventortopix.blogspot.com/2011/04/autodesk-inventor-2012-enhanced-mini.html
That is what the user and I are talking about. This does not come up when he clicks on objects, and by reading the Help for this program, it gives me the idea that it should appear?
OK, the toolbar you are talking about is in the Autodesk Inventor product. This forum is for the Inventor Publisher product. There are 2 different Autodesk products. Your question will get a better visibility in the Inventor forum http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
Autodesk Fusion
Join Fusion Insider
