A lot of materials in the Autodesk Library are locked.
Why is this and can I unlock them?
Hi there,
The Autodesk Material Library materials are locked as-designed. Publisher does not support custom textures at this time so changing the actual material texture isn't an option. However, after you apply the desired material from the library, you still have the ability to change the Scale and Rotation of the material on your objects using the Material Marking Menu.
Timera
