Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Locked Materials
1 REPLY 1
bowen192
1078 Views, 1 Reply
Locked Materials
A lot of materials in the Autodesk Library are locked.
Why is this and can I unlock them?
1 REPLY 1
TimeraAutodesk
in reply to: bowen192
Hi there,
The Autodesk Material Library materials are locked as-designed. Publisher does not support custom textures at this time so changing the actual material texture isn't an option. However, after you apply the desired material from the library, you still have the ability to change the Scale and Rotation of the material on your objects using the Material Marking Menu.
Timera
