Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Inventor Publisher 'Insert File Failed' Error
1 REPLY 1
sato2511
528 Views, 1 Reply
Hy!
I' ve a problem: when I attempt to load a iam with content center ipt, I view the attached message.
If I set the Inventor project file and copy the content center in local area it' s ok, if I set the Vault project and the content center is in network  I view the error " The content center ipt is in a network and not in Vault".
I don't understand wich is the problem.
Thank you.
sato
1 REPLY 1
Hello Sato,
Is this your content center parts tube and pipe?
Also using the Inventor project and having the content center parts on a server (not the vault) but just another machine may be, did that work? This test will eliminate the vault from the picture.
-Raj.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
