I am trying to install the 30 day trial of Publisher 2015 to try. I get to a point of installing the software but then it gives me this notification (see attached). I click okay, and continune installation then if fails the complete install. What does this mean? is it a simple fix?
I assume you tried to install Inventor Publisher as a system adim user? Please try to clean up the temp folder and install again?
C:\Users\rcrist\AppData\Local\Temp
-Huan
I installed the trial version of Inventor publisher 2015, but when I Tried to rotate the equipment program crash. I uninstalled and when I try reinstall program says that it is already installed, I already clean up the temp folder but it is impossible to reinstall.
Hello Huan,
Thank you for fast answer!
Yes I uninstalled from programs and features
Yesterday when I tried to uninstall for the first time I got the same error as bellow, and I used Revo Uninstaller, I saw this program in one forum answer.
this is the error since yesterday:
After no succes with Revo and reinstall I restored my pc to try to recover publisher.
The strange point is that was installed on my D Drive:
And the message was always that was installed on C Drive.
The only different thing was that my autodesk applicatin manager installed Publisher SP1
should i try with revo again?
Hello Huan, I tried to uninstall with all the ways and it is not possible, please see attached the errors screens
Huan, Thank you very much for the help,
It was missing one file in windows folder, Hard task to discover this but Finished!
Pardinho
