Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Inventor Publisher 2015 - Trails elbow after update 3D model
3 REPLIES 3
nicolas.striebig
606 Views, 3 Replies
I have a problem with Trail Elbow after update an iam 3D model.
After change the length of screws in Inventor, I update my model in Publisher 2015.
Trails elbow don't want follow the geometry ???
And after trying to remove/re-Add trails elbow, I've a bug when I want save the ipb file.
Do you have solution for that ?
Regards
Nicolas
3 REPLIES 3
na.miao
in reply to: nicolas.striebig
hi Nicolas,
 Could you please send me the ipb and inventor files, so we can do investigation for it? My e-mail address is na.miao AT autodesk.com.
 If the files is too larger to send, could you tell me your e-mail address, I will send a request to you to upload the files.
Thank You
Na Miao(Autodesk)
Inventor Publisher QA
na.miao
Hi Nicolas,
  Thank you for your dataset, I have send it to our developer team to do investigation.
Na Miao(Autodesk)
The only way I have found to fix this is to not let it happen by turning off the trails before the update and then turning them back on again afterward.  It has worked on the files I have had the issue on.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
