Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Inventor doesn`t open anymore
2 REPLIES 2
rotadig
1230 Views, 2 Replies
Hi all!
Well, last week i`ve installed the Autodesk Inventor Publisher 2011 x64 on my pc. But I`ve had a little problem in registrating it over the internet, so I closed the inventor and restarted.
But now, when I try to run the inventor again, appears a message error that says:
The Application is unavailable.
No license available. License does not exist or has expired.
What can I do? I tried to reinstall so many times, but the problem continues. I've installed even the Network License Manager, but I don`t know how it works!
Is there some thing to do to make the inventor to work like it was for the first time I`ve installed it on my pc?
My operational system is Microsoft Windows Seven Home Premium.
2 REPLIES 2
AlexFielder
in reply to: rotadig
I guess the problem you're having is because you've installed the program and the activation has failed probably due to a firewall or proxy.
The best way to fix this would be:
Uninstall the program completely.
Restart the machine.
Run the registry cleaner section of a tool similar to [CCleaner|http://bit.ly/bDicra] and remove any redundant registry entries.
Create a backup of your registry first! CCleaner should prompt you to do this.
Restart the machine again.
Try and reinstall.
Alex.
rotadig
Well, actually i`ve already solved the problem. I did all you typed before, and no way to work.
The solution was to restore my system in a backup made before I installed the Inventor Publisher. It worked!
Thanks for the Reply!
Rotadig
